psu hate?
Discussion in 'Hardware' started by Bruno_me, 4 Aug 2005.
  1. Bruno_me
    Bruno_me Fake-ad‎min
    30 Mar 2003
    well, as of late (last 3ish months), I've been having problems with stability regarding my video (fx5200 agp (dur)). basically what happens is..
    in windows:
    • hard lock whenever I do anything with 3d accelleration after ~5min.
    • sometimes, it renders the first few frames of a game, so if it fades in from black, I can see things dimly
    • in 3d rendering, etc. apps, it usually works for ~5min, then hard locks, sometimes with artifacts
    • overlay/2d works perfectly, except when I have 2 overlay windows going on seperate monitors
    • ctrl + alt + del does nothing
    in linux:
    • hard locks with 3d or overlay, non-accellerated 2d is fine though
    • time until lock varies greatly, I've had enough time to watch a whole movie without a lock, apparently it depends on what I'm doing, mouse movement, etc
    also, my psu is a pos. right now, the +3.3v line is at 2.83 (according to mbm and the bios, I cba using the multimeter). everything else is acceptable though (+- 5%)
    right now, I'm thinking, due to people suggesting it, that my psu is to blame, and the best course of action is to buy a new one, like this
    so yeah, what do you guys think? I've never had a problem with my video/mobo yet, and the problems started when the voltage dropped to 2.8ish from 3.2ish.
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    What PSU you got atm?
    You could do the get a meter to measure the lines properly
  3. TMM
    TMM Modder
    12 Jan 2004
    I'd check the PSU with a multimeter and replace it if the line really is that bad. Also check your graphics card and motherboard for any bulging/leaky capacitors.
  4. Bruno_me
    30 Mar 2003
    3.3 @ 3.17ish, then when I do something with graphics, it dips to 3.07ish. 12 is at 11.8, 5 is at 5.03
  5. Krikkit
    21 Jan 2003
    Well maybe you could do with a new PSU, but those lines are reasonable enough. Have you tried a different graphics card? Maybe that's the source of torture.
  6. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    the lines shoukd be within 5% of the voltage.
    and if you have 3.07 volts on the 3,3V line you have a problem...
    3.3v x 5 = 0,165v
    100
    3.3v- 0.165v =3.135v= the lowest voltage you should ever have on the 3.3V line.
    I would suggest a new PSU. Atleast try with a different one.
  7. Glider
    Glider /dev/null
    2 Aug 2005
    The lines should be wihin +-5%, but since your mobo is the only thing that uses the 3,3V line, it shoudn't be the source of the lockups...
    Since you get artifacts, I'd think it's a problem with the GFX card itself... Guess heat is the problem, because you only get it when you do graphical intens apps, wich require the card to work hard
    Just my $.02
    I suggest go to a clientfriendly PC shop... They can check what's wrong without you having to buy an expensive new PSU and/or GFX
  8. Smilodon
    25 Mar 2003
    GFX cards DO use 3,3V (atleast they have one (several?) 3.3v lines going to them) (what did you think all those pins in the PCI and AGP sockets are used for?)
    Besides, if it's a crappy PSU the loads on the other lines can affect the 3.3v (and other) lines. Todays GFX cards draw enough power to make a PSU on the edge to behave naughty ;)
  9. Bruno_me
    30 Mar 2003
    don't have another :(
    that's about what I'm getting
    nope, I reapplied thermal stuff just over a month ago
    I'm working on borrowing a psu/gfx. will report back with results
  10. Krikkit
    21 Jan 2003
    I would suggest buying/borrowing/stealing another. I've had PSU's that were 20% out of their rails and still the PC worked fine - it's too consistent a problem to really be a PSU problem imho.
  11. Bruno_me
    30 Mar 2003
    well, my psu is consistantly problematic ;)
    I am working on borrowing another psu/gfx, but my friend who will probably let me is out of town right now, so I can't test it very soon :/
