Modding psu in 5 1/4 drive bay
Discussion in 'Modding' started by roundyz, 16 Jan 2002.
  1. roundyz
    roundyz What's a Dremel?
    16 Jan 2002
    my case only has 1 spare 5 1/4 bay. it is a midi or mini, anyways the window looks crap cus there is a power supply unit covering half of it any suggestions for relocations? or maybe a drive box of some sort?
  2. brutal
    brutal What's a Dremel?
    7 Nov 2001
    mount it externally. take its current position and put it on the outside. cool thing is that you can put a blow hole directly over your mobo.
    if you keep the orientation the same, the atx cable should reach fine
  3. Felix
    Felix What's a Dremel?
    13 Nov 2001
    seen it done
    there was a tutorial about that somewhere (a PSU in a 5-1/4 bay) i think it was on the VH forums or maybe the [H] forum. if i find it, i'll tell you... you'd need some massive cooling on that sucka tho!
    Pax
    Felix
  4. Haddy
    Haddy World Domination
    22 Jan 2002
    i remember it being done in a pci slot before but i have no clue where it wuz
  5. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    Take a look at my first ever case which I put the PSU into.. there's not many real 'tips' on doing it, but it shows what I did which may have been some use.
