Modding PSU MOD todays task
Discussion in 'Modding' started by Bmw M3, 17 Feb 2004.
  1. Bmw M3
    Bmw M3 What's a Dremel?
    24 Dec 2003
    Well today it was time to change a PSU to make it tidy and look sweet,
    its was really easy just time consuming hardest part was the 4 pin and 20 pin atx block as them pins are hardest to remove i used two tiny pins first but took time so i stopped and order a tool the other day when i first started but now i have tool it was easy.
    i have used UV sleeving and molex shame i couldnt get uv shrink :waah: i have taken pins of the finished product and also a few pics showing how to remove pins from some of the blocks , for the female blocks i just used a tool and the atx a speacial tool but all the rest just needles "thanks mum" :jawdrop:
    so what do you think , i was happy with it i will try and get some uv night pics soon, only thing i wish i remembered was to put shrink on first would have saved me taking that dam atx block off again. :blush:
  2. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    Yea good m8 did the same to my PSU yet it did did not turn out right! :'( :waah:
  3. Bmw M3
    24 Dec 2003
    what happened? :wallbash:
  4. Abyss
    Abyss What's a Dremel?
    20 Jan 2004
    I think it's a great mod and it looks good. It's a shame you did it the hard way first and only got a tool to help at the end, but it seems the hard way usually comes first. Good work.
