PSU PSU upgrade neede for 680 SLI?
Discussion in 'Hardware' started by smc8788, 12 Feb 2013.
  1. smc8788
    smc8788 Multimodder
    23 Apr 2009
    I've been considering adding another 680 to my system, but am a little unsure of whether this would warrant a PSU upgrade as well. I'm currently using a Corsair HX650 which is getting on for a few years old now. All the other components would remain the same, namely:
    i5 2500k OC'd to 4.2GHz
    3 x HDDs
    1 x SSD
    4 fans and 1 H60 for cooling
    My gut feeling is that it would be cutting it a little close, but that's not a very scientific way of deciding whether I need a new PSU or not. I'm not using any of those PSU calculator sites either as I know they're a load of rubbish. Any thoughts?
  2. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    You could just get away with a 650w PSU but you might be pushing it to its limit. I'd go for either a 750-850w Corsair AX units
  3. docodine
    docodine killed a guy once
    10 Feb 2007
    +1 to what flame said
  4. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Get a £10 power meter and check the power consumption yourself.
  5. flame696
    15 May 2009
    Or as mm vr has said and get a power meter (which is what I need to get), and see how much the rig is really pulling power wise might even save you a few bob
  6. rollo
    rollo Modder
    16 May 2008
    680 sli on system you linked will be fine on that system. I run a similar setup but with an older higher watt CPU ( i7950)
    Below 400 watts in most games. 510-530 benching.
  7. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Ah screw it, I think I'll just grab myself of the 750W/850W platinum PSUs to be on the safe side :)
    The HX650 is the only thing I haven't bothered to update over the last few years, so I guess it's due an upgrade anyway.
  8. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    They cost an arm and a leg though, have fun :)
  9. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Yup, but since they're the only component in my system that I can see lasting the next 7-8 years, I see it as a worthwhile investment ;)
  10. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Worthwhile having a look at the range Enermax offer; really stupendous PSUs! In truth I'm very very underwhelmed with my (third!) Corsair AX850, it has been so much trouble with two failures thus far.
