PSU , Watercooling , Case
Discussion in 'Hardware' started by WaLLaWaLLa92, 11 Aug 2005.
  1. WaLLaWaLLa92
    WaLLaWaLLa92 What's a Dremel?
    27 Jul 2005
    Erm...yes , i have a question , Do you think the Beantech BT-82 Acrylic case - ( http://www.themodhouse.co.uk/store/...1ec53c3e97f4bfe ) , Do you think that case on that link wud be able 2 accomadate this dual 120mm water cooling kit - ( http://www.overclockers.co.uk/acata...plete_Kits.html ) , - its the 2nd 1 down the page-. My question is , do you thnk the beantech case wud be able 2 accomodate this watercooling kit , taking into consideration PSU space , which shud be roughly 15-17cm (i shud be using antec neopower 480w PSU) , drives arent a problem cus i cn move thm down a couple of bays so i have space towards the front alot more.
    I think this wud be a tight fit fitting those 2 fans on the top of this case , and would it be a tight fit inside due to wires and pumps etc?? , just wondered if any1 cud help really , thnx.
    Also , wondered this psu , its 24 pin connector (http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=64849
    Do you thnink the DFI Lan Part nf3 250gb Uv mobo , 754 will support this , well actually will the psu be able 2 use 20 pin connector aswell as 24pin or not?? , thnx. :p
  2. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    How many threads do you need? :/
  3. WaLLaWaLLa92
    27 Jul 2005
    Its ok , i decided to mount thm on the side of the case , that way the radiator will be low down and theyll both fit on the side of the case , opposite the mobo , it shud work well , but thnx neway...
