PSU PSUs with black, non-braided cables?
Discussion in 'Hardware' started by ry@n, 16 Feb 2009.
  1. ry@n
    ry@n Minimodder
    31 Aug 2005
    Does anyone know of any PSUs that come with modular cables like these? Apart the Ultra x3 of course. they look great and look like they have a better bend/fold radius than braided cables.
    Any suggestions appreciated!
  2. Stig
    Stig What's a Dremel?
    21 Dec 2008
    The CorsairHX series have those...but only on their MODULAR cables. The non-modular cables on those PSUs (they have both modular and non, which I find kinda weird, but I guess it works) are braided. So if you can live with some of each, thats not a bad way to go, since they are great PSUs.
  3. wyx087
    15 Aug 2007
    what's braided mean??
    Corsair Hx have those cables with modular ones, the attached (eg, the 24pin mobo power) are not like the photo though.
  4. mooseguy
    mooseguy Crazy Moose
    17 Oct 2008
    Braided means they look like this:
    The Corsair HX series cables are all black ribbon cables, apart from the 24 pin connector, and the 4 and 8 pin connectors for motherboard power.
  5. ry@n
    ry@n Minimodder
    31 Aug 2005
    Ok thanks for your replies, it's a shame that the HX series jumps from 620w (isn't going to run my system when I get a pair of cards in SLI and a new mobo) to 1000w (which costs £190, so is out of the question). Any other suggestions? Probably should have said this initially but I am looking to spend around £120.
  6. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    What's wrong with the ultra? it isn't a corsair, but I have one of the older x2's with the same cabling but mine are UV reactive, and never had an issue, and it looks sweet in a black case with blue mobo and fans.
  7. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    You won't even be pushing a 620W with dual 7900's and an OC'd quad. Just get the HX620, that'll be more than fine. :)
    Oh I noticed you're going to get new cards. But I still think you'll be fine with the 620. Dual 4870X2's are starting to push it a bit.
  8. azrael-
    azrael- I'm special...
    18 May 2008
    Just to jump in as a grammar nazi here: in this context the cables aren't so much "braided" as they're "sleeved".
    I know, I know... I just *had* to comment on this... :p
