Electronics Pump relay ques
Discussion in 'Modding' started by olle, 26 Jun 2006.
  1. olle
    olle What's a Dremel?
    26 Nov 2005
    I bought a pump relay and wondering how to connect it.. :wallbash:
    The pump has two wires one brown and one blue, and on the relay its thre connections marked G, L and N, AC OUT
    Any hints!?
  2. Pal_Mal
    Pal_Mal What's a Dremel?
    30 Jun 2005
    is it a 240v pump and the relay is 12v ?
  3. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    blue - neutral
    brown - live
    ground - green/yellow striped
    thats for the UK anyway (and europe i think)
    G - ground
    L - live
    N - neutral
  4. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    pictures would be helpful, as would any other lettering or numbering, like model numbers etc on the relay.
  5. Pookeyhead
    30 Jan 2004
    Sounds like the same one I have. Post some pics, and I can tell you (or anyone else who's ever used on I imagine).
  6. DougEdey
    5 Jul 2005
    Brown *may* be colour coded as neutral/earth and blue therefore live, but blue normally means negative to me.
  7. TheoGeo
    10 Jun 2003
    sounds like your getting horribly mixed up between AC and DC. What i posted is the correct current UK wire colours. The old ones were different but what he is using is clearly not the old british standard as that is black and red.
    all he has to do is connect blue to N and brown to L. There is no ground on his pump so that is not needed
  8. olle
    26 Nov 2005
    Don´t have any camera.... Anybody who wants do donate one?
    blue to N and brown to L........... Its alive!! Thanks dudes!!! What should the world be without the forums!?
