Other Punching holes in material, and then putting an eyelet(?) in it
Discussion in 'General' started by liratheal, 27 Jan 2017.
  1. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Okay, the title didn't help much at all.
    I've got a little faux-leather pouch.. Thing. That I keep one of my alarm fobs in. The fob itself was designed by a halfwit, and the loop is a perishable rubber piece of nonsense.
    This pouch thing is not all that great an alternative, because I can't put it on a key ring and take it with me without losing it. So I thought "I have a leather hole punch, why not put a hole in it?"
    But then I figure it'll rip with constant use. So I had a second thought - Eyelets on boots! That'd add some rigidity and keep me happy it'd last longer than ten minutes.
    However. The procedure for doing so eludes me.
    Anyone got any clues?
  2. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
  3. liratheal
    20 Nov 2005
    You are much better at googling than me!
    Cheers for the links!
  4. mrlongbeard
    31 Jan 2010
    Nah, I've have and use the wheel punch for leather and I have and use the regular punches and rivets on canvas.
  5. liratheal
    20 Nov 2005
    Ahh, well, I appreciate the quick response!
  6. RedFlames
    23 Apr 2009
  7. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    Most hardware stored will sell you a grommeting kit which is good for doing a small project. If you're doing more than about a half dozen, buy a real hollow punch and always make sure you're using 2 piece grommets. The 1 piece ones don't even work well for decoration, much less holding anything.
    Something like this:
    http://www.ebay.com/itm/General-Too...535149?hash=item41ba3e8aad:g:TyEAAOSwEzxYUOFd
    Note that there are two parts to each grommet. You punch the hole with the sharpened hollow tube, put the "male" part of a grommet on the mandrel, place the material over it so that it sticks up through the hole, place the "female" part over the male part and the material, then place the, uh, long round conical thing into the hole on the male part and start hammering. The male part deforms downward, sandwiching the female part and the material together and holding it securely.
  8. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Was in wilkinsons today and saw they had a set of eyelet pliers which comes with 100 eyelets, only £5.99, has a hole punch built in too to give you the right size for the eyelets.
    linky
