Modding Push pins, help plz!
Discussion in 'Modding' started by STi305, 1 Apr 2004.
  1. STi305
    STi305 What's a Dremel?
    20 Feb 2004
    hiya,
    how do you remove push pins already holding fans in place. i have a lian li pc 60b, and im replacing the fans with panaflos. any help would be greatly appreciated, thank you.
    p.s. the push pins are plastic, and appear to thread through the hole then open up.
    thanx
  2. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    They are not threaded, they push right out.
    MS
  3. kevplus2
    kevplus2 What's a Dremel?
    23 Mar 2004
    they are actually 2 pieces. from the pointed end (inside) push the center and a pin with the head will come out. then push out the remaining piece
  4. tk421
    tk421 Idiot.
    15 Jan 2002
    i always used the smallest flathead screwdriver in a jeweler's set to push mine out ... works every time
  5. modsquad
    27 Feb 2004
  6. modsquad
    27 Feb 2004
    There is not much retention with those things, I used my finger-nail. Did I say I hate those things>>>>>>>>>>>>>MS
    http://server5.uploadit.org/files/jeffrey9-IMG_0442.jpg
  7. STi305
    20 Feb 2004
    lol,
    thank you guys, i hate em too, but now i dont have to worry about them anymore!
