Modding Q: Re: "Macro Black" article/project
Discussion in 'Modding' started by Cicada, 16 Apr 2003.
  1. Cicada
    Cicada What's a Dremel?
    29 Nov 2001
    what is hte painting method called when he painded the side panels black, and looks black when the lighting is off, but is a window when the lights inside are on?
    and how do you do it?
  2. Cicada
    29 Nov 2001
    also, how was it done with the VFD?
  3. GT3_GOD
    GT3_GOD What's a Dremel?
    6 Nov 2001
    Its a special type of tinting film I belive. The clear case was painted so that there was that gap in the middle and then this tinting film was applied there so when its off it just looks like a black case and when its on it comes to life.
    Same method was used on the VFD IIRC.
  4. ISM
    ISM What's a Dremel?
    6 Mar 2003
    if you read the article he tells you how to do it........ i think :rolleyes:
  5. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    From whai I undestand he used automobile window tint. Read the article it is all in there somwhere.
