Quad Core i7 2.4Ghz expected PPD on bigadv?
Discussion in 'bit-tech Folding Team' started by Votick, 26 Mar 2011.
  1. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    What could I expect from a Quad Core i7 2.4Ghz on bigadv?
    First of all overclocking is out as its a server so the warranty will be void.
    And the reason I can run it 100% load is the hardware is under warranty.
    Also dose RAM make a diffrence to it?
  2. Gareth24
    Gareth24 Folding = vdubs
    16 Jun 2009
    I believe you need an overclock of at least 2.8Ghz on an i7 to complete bigadv units on time although I could be wrong. SMP units should still bring in a fair amount of point though.
  3. Votick
    21 May 2009
    so i could run 4 SMTP's of 2 cores or 2 of quad cores
  4. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Its not 2.8Ghz, its 3.8Ghz with hyperthreading at the bare minimum. Any GPU folding and you will need even faster.
  5. Votick
    21 May 2009
    Spoke to saspro and ive had a word with the provider tomorrow when it goes down for the ram upgrade a nice 4ghz i7 will be dropped in.
  6. One_Box
    One_Box Folder of the month April 2012
    11 Jul 2010
    Is it just one 4 core processor with hyperthreading we are talking about ?
    If it is make sure hyperthreading is enabled and run just one instance of SMP. When you are happy with everything you could include the -bigadv flag to boost your points.
