Modding Question bout fishing
Discussion in 'Modding' started by ede670, 1 Aug 2004.
  1. ede670
    ede670 What's a Dremel?
    26 May 2004
    Hi all need your input if poss.....have braided my cables in pc case with clear braid..
    I was going to buy el wire to wrap round the braiding as I have 2 12" UV's
    fitted as well but seen this and thought this might show up ok if I bought it in say 50lb class...
    http://www.sportfishingbc.com/articles/tackle_reviews/berkleys.htm
    You think or not there are also other lines available in yellow and blue as well thought this might be a cheap alternative
  2. MrBurritoMan
    MrBurritoMan What's a Dremel?
    27 Jun 2004
    that should(note i said should) glow. all you will need is a light source if you are planning on substituting that fishing like for the real EL wire. if used in conjunction then that fishing line would work great! :thumb:
    [EDIT] now that i have actually thouroughly read your post that fishing line would look really good [/EDIT]
  3. MRKIKKOMAN5645
    MRKIKKOMAN5645 What's a Dremel?
    2 Aug 2004
    i agree b sure those cold cathodes r uv tho.. awesome idea with the fishing line :rock:
  4. ede670
    26 May 2004
    Have used it and glued it on to the spiral wrap found blue uv line and wound it round and shows up a treat really bright.I have not got a digi to show you guys but this mod cost me 2 pounds for 50 meteres .....and really stands out with 2.... 12" uv cathodes
  5. Miirk
    Miirk What's a Dremel?
    26 Jul 2004
    Great idea!
    If anyone could upload some photos of it that´d be great!
  6. Firehed
    15 Feb 2004
    Yeah I like that too. Sure a lot cheaper than EL wire :) With some luck I can think of a way to use that idea :hehe:
