Build Advice Question from an idiot.
Discussion in 'Hardware' started by dtheg1986, 23 Sep 2011.
  1. dtheg1986
    dtheg1986 What's a Dremel?
    25 Nov 2008
    hi guys,
    so I've been a long time reader (and member) but I never ever post. I mainly read the site for gaming news if Im honest.
    But the day has come, so, Im totally looking to buy a new computer, some kind of powerful beast that will play all my games, has a super huge hard drive and is generally awesome.
    The issue is, Im totally useless at modern day specs, a good place to go buy a machine, and I wouldnt trust myself to build it, so ideally, I'd like to buy it premade.
    My budget is circa. £1000 for the tower with THE POWER. Apologies for my pun there.
    Any tips where to go what to get as some kind of graphical gameplaying powerhouse beast machine ?
    Oh sorry, also I forgot to add this in -
    Budget: £1000
    Main uses of intended build: Gaming
    Parts required: Everything except mouse,keyboard and monitor
    Previous build information (list details of parts): N/A
    Monitor resolution: 1920x1080 (at least if not better!)
    Storage requirements: 2TB
    Will you be overclocking: Dont really know how ?
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): No requirements
    Extra information about desired system: I want to buy the system pre built as Im an idiot and cant make things.
    Thanks a lot,
    Dave
    P.S. if it had a couple of HDMI outs that would be super awesome so I could connect it to my TV.:clap:
  2. Lance
    Lance Ender of discussions.
    6 May 2010
  3. Saivert
    Saivert Minimodder
    26 Mar 2005
    forum heuristics
    wouldn't be that hard to just detect a couple of keywords and make the forum auto post it as well. even show a warning before the user posts using javascript magic.
    "the post you are about to submit might be related to this <link>"
  4. dtheg1986
    25 Nov 2008
    Hi Lance, but the thing is, I wouldnt want to build it, I want to buy it prebuilt, so do you have any other ideas there ?
    Thanks,
    Dave
  5. Saivert
    Saivert Minimodder
    26 Mar 2005
    where do you live? hard for us to point you to any retailer/e-tailer if we don't know where you would be ordering your stuff.
    Scan has prebuilt machines. and I know several component e-tailers that also can build a computer for you for a fee. You have full freedom of components. They just put it together for you. Or you can pick from their kits.
    edit: then there is also Alienware and other boutique brands.
  6. Lance
    6 May 2010
    PC specialist build a PC for a friend of mine and he based it on the Bit-Tech list above, but actually put it into their cheapest case. And I was actually really impressed, small, and didn't die of Lan Death in the heat.
    Also the 560 ti (and I believe the 570) has a HDMI output on it :)
  7. Bede
    Bede Minimodder
    30 Sep 2007
    Scan's builds seem pretty good, but I'm losing faith in them as a company. You could probably choose all your parts and then get a local tech guy to put all the bits together for £50 (especially if you can find a student :D) - best of both worlds!
  8. dtheg1986
    25 Nov 2008
    haha, I see, ok, well, Im not really sure, I suppose Ill go with PC Specialist or Scan and maybe list those components ? Hope that all sounds good.
    Erm... if anyone is interested, ill post how it all ends up!
    Thanks a lot for the assistance guys,
    Dave
  9. Carrie
    Carrie Multimodder
    18 Nov 2010
    Or maybe tell people what part of the country you're in and perhaps someone here would offer their services for a fee, as happened when I first joined up to build one (not that he delivered on the offer though lol - you know who you are!:p )
    Teelzebub likes this.
  10. Lance
    6 May 2010
    Good luck with the build. Sorry about the grumpy first reply ;)
  11. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    Scan or YoYoTech would probably be the best bet. The YoYoTech Warnird had a decent review in Custom PC a while ago. Can't really see a reason for newer version to be worse. 3XS systems from scan are good as well :)
    EDIT: Spotted a typo for Warbird reading Warnird, but i think i like it better lol
  12. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    I pretty much used the custom builder on Yoyotech and added everything I wanted bar the keyboard/mouse and some extras and it cost more for parts than where I'm buying all mine from.
    Instead of buying from more than one retailer I'm using just the one. And the main reason for that is they have everything in stock for delivery. Plus I'm buying a generic 570 instead of a pre overclocked version.
