question regarding dremel
Discussion in 'General' started by Veer, 10 Jan 2006.
  1. Veer
    Veer What's a Dremel?
    3 Dec 2004
    i recently ordered a Dremel from the states, which runs on 120 V. Is there anyway i can get transformer for the dremel to increase the voltage to 220 V so i can use it here in ireland ?
  2. MonkeyTurnip
    MonkeyTurnip What's a Dremel?
    23 Aug 2005
    yep you can get a step down transformer from some where like maplins.
    why did you buy it from the states cos buy the time you buy the transformer etc it will be more expensive than buying on from the UK
  3. Veer
    3 Dec 2004
    I accidentaly bought it, I was thinking that the dremel might be an international model. :S. I got the dremel for only $55 including postage. Since a dremel on average costs between euro 85 - euro 120.
  4. MonkeyTurnip
    23 Aug 2005
  5. Veer
    3 Dec 2004
    nice one, thanks for the link. :)
  6. Krikkit
    21 Jan 2003
    Don't forget that's only a 45W convertor - check the Power rating of your dremel before you go buying and plugging.
  7. Veer
    3 Dec 2004
    yep, i am aware of that. just out of curiosity how much would a dremel cost in the UK?
  8. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    It depends on the model, and whether it comes with accessories or not? Have a look here for models and [example] prices.
    Although it's now been discontinued by Tooled-up... I personally use a MultiPro 395...
    [​IMG] [​IMG]
  9. Veer
    3 Dec 2004
    thanks, i will have a look at it.
