Electronics question regarding tft's
Discussion in 'Modding' started by Veer, 19 Feb 2005.
  1. Veer
    Veer What's a Dremel?
    3 Dec 2004
    firstly i don't know much about lcd screens. I have been looking for a cheap color lcd screen for a project i am working on. However I have some questions.
    link
    link2
    in these links. I am not sure of if these displays come with a controller or not.
    I am looking for one which comes with a controller, so as to avoid any hassle of trying to hack the lcd and trying to get it to work.
    all help will be appreciated.
    link3
    here is the main page.
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    The second module you posted looks like it has a controller, however AFAICS it's not VGA, DVI or VESA compatible. Each of those only has one pin for color data, while the module requires a 3 bit number for each color. Not sure whether you're trying to use your graphics card with it or drive it with a PIC or what, but it probably won't be easy. Which I could help more, but that's about all I can tell you.
  3. Veer
    3 Dec 2004
    ah right, thanks a lot for the feedback. I want to run the module using my graphics card.
  4. Veer
    3 Dec 2004
    are there any places where i can get screens/modules with controllers for roughly under $ 100. That can work with my graphics card?
  5. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
    Your best bet is a 7" car LCD. Look for one with NTSC/PAL input. I would stay away from VGA/VESA input LCDs, as these sometimes come without the necessary control circuits to work (they are VGA compatable, not directly driven).
    For about $100 you can find a car LCD either on Ebay or sometimes at DIY MP3 player websites. Look around, google 7" TFT.
  6. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    I was planning on getting a small (5-7") LCD a while ago... I actually figured out that those car LCD's was more expensive than most 15" LCD monitors... So i ended up buying a monitor that looks like those i alredy have just smaller for running system stats and Winamp... Saves you for lots of work, and you get a bigger screen, and most likely you'll get a better image, and you don't have to convert it to a compsite signal and back.
    Why is there so few car LCD's with VGA or DVI connections?
  7. Veer
    3 Dec 2004
    true! The car screens are doubtedly more expensive then a 15" tft screen. The thing is i don't want to spend a lot of money on something which shouldn't cost a lot. I'd buy a 7" tft for $ 50-100. But wouldn't want to pay anything more then that. As far as 15" are concerned, that is my very last option.
