Electronics Quick component question
Discussion in 'Modding' started by mikecx, 19 May 2003.
  1. mikecx
    mikecx What's a Dremel?
    24 Nov 2001
    at http://www.rabidhardware.net/index.php?id=5 they have a guide for a pulsing LED. I can't find the needed parts at digi-key so I am looking at mouser and I've found two that appear close to me but I'd like to know if they will work since I know very little about electronics.
    To substitute for the Digi-key Part #LM1458N-ND ( LM1458N )op-amp.
    http://www.mouser.com/index.cfm?handler=displayproduct&&lstdispproductid=378795
    and
    to subsitute for the Digi-key Part #2N3904-ND ( 2N3904 ) NPN amplifier.
    http://www.mouser.com/index.cfm?handler=displayproduct&&lstdispproductid=272287
    Also, for that last 100ohm resistor I cannot find it in1/4 watt. Will 1/8 watt work?
    Thanks,
    mikecx
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Those two links you posted are for the exact same thing in the article. Good thing you didn't accidently order any SMD parts, since those are NOT for beginners.
    1/4w 100ohm resistors (having print catalog is handy).
  3. mikecx
    24 Nov 2001
    Thanks whypick1, I have a general knowledge of electronics but not near as good as I hope to have.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    If you're thinking of buiding the rabid circuit you may be interested in this Phaeton thread. ;)
