Graphics Quick, dumb question about Vulkan API
Discussion in 'Hardware' started by Pete J, 14 Sep 2016.
  1. Pete J
    Pete J Employed scum
    28 Sep 2009
    Hi all,
    How exactly is Vulkan installed? Does it come with the GPU drivers, or from programmes that use them, such as Doom?
    I ask because when I install new drivers, I do a clean sweep with DDU and one of the options is to uninstall Vulkan. I'm just wondering what re-installs them!
  2. theshadow2001
    3 May 2012
    Runtimes are usually installed by the programs that need them. Although I don't know specifically for vulcan that's usually the way 5hings work on windows
  3. Pete J
    28 Sep 2009
    That's what I'm thinking. I wonder if I uninstall them, will Doom reinstall them automatically next time I fire it up? Only one way to find out I suppose...
  4. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    I think they come with graphics driver install. I saw something before when doom implemented Vulcan.
    In the test they had different runtimes from each driver for the AMD and Nvidia tests.
