Windows Quick Heeeelp!! Boot order problem.
Discussion in 'Tech Support' started by ajangusjames, 2 Mar 2013.
  1. ajangusjames
    ajangusjames What's a Dremel?
    26 Dec 2011
    Ok, lets get straight to the point:
    I am upgrading my fathers pc for him; adding an ssd and wifi card which have completed with only one problem:
    in the bios there is not enough options within the boot sequence for the ssd to fit in, there is only floppy drive, cd rom and ide drive which are locked. I have to boot through advanced boot sequence every single time!
    Any help is appreciated! (his computer is a dell dimension 46000 :D :D :D :D
  2. Krikkit
    21 Jan 2003
    How can there be no option to choose an SATA boot device? Must be in there somewhere!
  3. ajangusjames
    26 Dec 2011
    boot sequence in bios:
    "1.hard-disk drive c;
    2.Floppy device
    3. IDE CD-Rom device"
    I have swapped sata connectors but it replies with "NTLDR is missing", trust me have swapped everything and configured the bios but as there is so little options I have to enter the boot menu every time!
    Thanks
  4. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    Did you check for a bios update?
    Sent from my GT-I9305 using Tapatalk 2
  5. ajangusjames
    26 Dec 2011
    A bios update is the only thing i didn't bother doing ill try it now!!
  6. ajangusjames
    26 Dec 2011
  7. ajangusjames
    26 Dec 2011
    There isnt an available bios update :(
  8. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Is the ssd the only hard drive in the pc? If not there is probably another menu for hard drive order specifically in the bios.
  9. ajangusjames
    26 Dec 2011
    No there is a separate sata hdd, Ive just found out that xp set the ssd to D:/ so that it doesn't boot to C:/ as it does not exist i am trying to change the boot letter!
  10. IvanIvanovich
    31 Aug 2008
    I would advise to just disconnect hdd, make sure that ssd is on port0 of the sata controller and re install. Once install is finished reconnect the hard drive. It's pretty much impossible to change the drive letter of the boot device without breaking everything. Also having only the ssd connect during install ensure the boot files are put on the correct drive.
  11. ajangusjames
    26 Dec 2011
    Ok thanks to everyone, i have fixed the problem. In the end it turned out that when reinstalled windows xp onto the ssd the drive letter was D:/ instead of C:/ so I simply reinstalled it again and it booted normally! RELIEF!
    Thanks
  12. spolsh
    spolsh Multimodder
    4 Feb 2012
    Might be worth looking for threads about running an SSD on XP. I'm sure I've read of some optimisation tweaks being useful.
