Electronics Quick LED Question
Discussion in 'Modding' started by cool_dude, 8 Apr 2007.
  1. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    Going to be supplying some leds with 5v....the led's require 3.2v - however i don t know what resistor i need to go for :(
    tech specs of led:
    Trying to do the working out...
    V = I x R :
    5 = 0.03 x R
    So...
    R = 5 / 0.03
    =166.66
    So does that mean for that LED to function at 3.2v using a 5v line i will need a 166 ohm resistor??
    btw i want to wire them up parallel!
    Help appriciated.
    thanks,
    c_d
  2. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    I wouldnt run it at 30 mA, as thats the maxium and you risk burning LEDs out quickly, especially if you get one with a lower Vf then normal. And the V that you want to use is the difference between the LEDs voltage and the power supply, not just the power supply.
    so 5-3.0 = 2V
    R = 2V / .020A = 100 ohms
    For paralleling you would just give each LED its own resitor and hook it up the the 5v line.
    However... what I would do is put 3 in series, giving you 9v for the LED string, and power them off the the 12v line.
    so that would be:
    (12v-9v)/.02 A = 150 ohms
    Dont know what you're going to be using this in and if a series or parallel operation would work better for you. Either would work fine. Just dont be tempted to put 4 in series and put it across the 12v line with no resistors... you could get a few LEDs with a Vf of 2.8v. So the Vf of the string would be 11.2v then. Feeding that 12v would draw a lot more current then the LEDs are meant to handle , and it would end up frying.
  3. agent420
    agent420 What's a Dremel?
    18 Apr 2006
    ... or just use this led calculator... The series-parallel calc they offer is nice as well.
