Electronics Quick PIC question
Discussion in 'Modding' started by mikecx, 20 Apr 2004.
  1. mikecx
    mikecx What's a Dremel?
    24 Nov 2001
    I'm going to buy a 16F877 to mess around with but looking at mouser.com and digikey.com they have them in tons of different sizes and packages. I was wondering which one I should buy that would be the easiest to program and then the easiest to breadboard.
  2. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    40-pin DIP...
    CD :)
  3. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    Program depends on the type of programmer, there are LVP (Low Voltage Program) ones now, which imo arn't realy worth the hassel, but thats because i have a 13v programmer.
    I/P is DIP/DIL packing.
    16LF877 is the low voltage programming counter part.
    JDM/Poney work best with non LVP versions (you have to pull a pin high with a resistor).
  4. mikecx
    24 Nov 2001
    Mines based off the JDM design so I just need the 16F877 (non-low voltage) in the 20 pin DIP, sound correct?
  5. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    16F877 is a 40 pin device.
    DIP is vritually the same as DIL.
    So yes.
  6. thecrownles
    thecrownles What's a Relix?
    27 Feb 2004
    go to microchip.com and get some free samples of the 16F877A, you can program that with JDM too.
  7. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    Only use free samples if your making a design, for a product that you plan to produce, otherwise its abuse.
  8. thecrownles
    27 Feb 2004
    oh, i see. sry bout that
  9. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
    Digikey and mouser both have a minimum charge order ($25 or they charge handling fee).
    Try here for a better place to get PICs. Cheap shipping too.
