Graphics Quick question about Dual GPU non SLI mobo
Discussion in 'Hardware' started by Arghnews, 28 Feb 2013.
  1. Arghnews
    Arghnews What's a Dremel?
    6 Jul 2011
    So it's in the title. If I'm going to put a 690 or the like into a single PCI-E slot on a non-SLI supporting mobo, will there be any problems? (What does the SLI chip actually do then?)
    Blame Crysis 3 and my friend asking :D
    Cheers and sorry if it's been posted before had a look about couldn't find
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    The GTX 690 itself contains the necessary chipset to SLI with itself!
    That's not to say that it'll enable you to add a second GTX 690 because your motherboard is still incapable of SLI.
    Arghnews likes this.
  3. Guest-44432
    Guest-44432 Guest
    Th more important question is what chipset is your motherboard, as running a GTX 690 on a PCIe 2.0 x16 slot will cripple the performance.
    As stated above you can run any Dual GPU card on a non SLI/Crossfire motherboard. :)
