Electronics Quick question - LM3914
Discussion in 'Modding' started by tmod, 19 Jul 2004.
  1. tmod
    tmod What's a Dremel?
    9 Apr 2004
    I've got a common cathode bargraph display...which means, from what I've read, it won't work with an LM3914. Am I wrong? If I'm not, any simple alternative solutions? I'd like to still use the bargraph I have.
  2. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    Stick an octal inverter between the IC and the LED array.
  3. tmod
    9 Apr 2004
    I knew there'd be a good solution here. Thanks! :thumb:
    EDIT: Is the 74HC540 what I'm looking for?
  4. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Nope, need something that can supply a bit more juice on the outputs, like the 74ACT04
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    This a 10-led display? 2 hex cheaper/less bulky than 2 octopi, lots of choice. ;)
    whypick1 beats me to the tape :p
  6. tmod
    9 Apr 2004
    @ whypick1 - that looks good, but I'd imagine something with all the outputs on one side would make it a bit easier to build on stripboard, I'll check for one
    @ cpemma - yes, it is a 10-led display
    Hmm, looks like only the octal inverters have the outputs on one side. I'll probably just stick with the hex inverters though.
