Hi guys, Just need to know if using A DVI cable instead of a VGA cable makes a noticable difference? Thanks
personally I dont theres much of a difference. Although I do prefer crt monitors, the colour just seems better, which is wierd in away you'd assume the quality would be much better using a DVI cable and TFT since theres no DAC taking place. I suppose it a person preference.
If your asking whats the difference between DVI and VGA. Well, LOADS. Depends if you have good eyesight though heh, if your blind as a bat, your not going to see any difference what so ever. If on the otherhand have good eyesight, you'll see the different straight away on the bootup screen. When I use a VGA monitor I just hate it now.
depends on the length of cable, and how much interference it's likely to incur. If it's a short run, with no other sources of interference, then the difference may be minimal. If it's running along side mains cables or in an electrically noisy environment, then DVI may yeild better results.
