Quick Question
Discussion in 'Hardware' started by matt.slysnake, 8 Mar 2007.
  1. matt.slysnake
    matt.slysnake Banned
    27 Dec 2006
  2. atanum141
    22 Jul 2004
    its only got one ethernet port. i know you can connect it via usb but its gonna be an issue in the long run when you want to add further machines to it.
  3. matt.slysnake
    27 Dec 2006
    It is very unlikely that it will be necessary for it to be connected to other machines, but the router connecting to one PC via USB, and the other one via ethernet cable is OK?
    I am a little wary of this because it's so cheap, so would it be good quality ?
  4. Hiren
    Hiren mind control Moderator
    15 May 2002
    General rule of thumb: Avoid cheap routers like the plague unless you like dealing with lots of random issues.
    Secondly I'd look for a router that's actually made by a networking company rather than one that's famed for soundcards.
  5. Krikkit
    21 Jan 2003
    Yep, avoid it like the plague, creative are famed for having bad driver support, and bad support for a router is the last thing you want.
