Electronics quick question
Discussion in 'Modding' started by MajestiX, 23 Aug 2002.
  1. MajestiX
    MajestiX What's a Dremel?
    14 Apr 2002
    is it ok to tap power from a line will it change the performance of a drive???
    Code:
                        5v to LEDs     ground to LEDs
    --------------/---------------/------------> ground to hard drive
    ------------/------------------------------> 5v (red) to hard drive
    Cheers,
    MajestiX.
  2. Holst
    Holst What's a Dremel?
    17 Nov 2001
    As long as you are connecting in paralell with the drive (onto +12 and +0) then you are fine.
  3. MajestiX
    14 Apr 2002
    so i guess that means nothing happens...
    thanks
