Planning Radiator visible from the outside
Discussion in 'Modding' started by Ansamech, 25 Sep 2020.
  1. Ansamech
    Ansamech What's a Dremel?
    25 Sep 2020
    Hi, brand new to bit-tech and getting ready to do my first ever full build mod. Im doing an industrial/cyberpunk/dystopian theme and Im thinking it might be cool to have the grill of the rad as close to flush to the case wall as possible and cutting it so just the grill(not the frame of the rad) is exposed. The problem is I haven't been able to find ANY pictures of anything similar, which while is cool cause it means my idea might be semi unique, it is also annoying cause I dont have a reference to know if it is actually gonna look cool. So if anyone has any pictures possibly demonstrating this, or at least something close, I would love to see them! thanks.
    LisaScott123 likes this.
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Just remember if the RAD is exposed its really fragile so will get damaged!
  3. Ansamech
    25 Sep 2020
    Yep! definitely taking that into account, but thanks for the reminder:)
  4. Bloody_Pete
    11 Aug 2008
    Also will it be in intake or an exhaust?
  5. Ansamech
    25 Sep 2020
    its the front of the case, so I think intake, which would unfortunately make it pull not push.
  6. enbydee
    enbydee Minimodder
    10 Jul 2014
  7. Ansamech
    25 Sep 2020
    Ooo thanks for the pics! Im not a huge fan of the rad cover look, or at least for what I have in mind. As for the screws the idea would be not showing them, so that its a seamless transition from rad fins to case.
  8. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    On my computer case, the radiator is pretty much exposed:
    [​IMG] [​IMG]
