Modding Radiators at the bottom of the case - heat issue?
Discussion in 'Modding' started by phinix, 14 Sep 2008.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    This may sound stupid, but need to ask anyway:)
    I was wondering when you mount radiators on the bottom of the case, so the fans will blow the hot air out straight on your desk - will that defect your desk after, lets say, a year of blowing hot air? Something like a fade colors (wooden desk)?
  2. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    What kind of desk/wood?
    Edit: I'd be more worried about the weight of the case rather than the heat TBH.
  3. Krikkit
    21 Jan 2003
    It's not hot enough to affect the wood tbh. :)
  4. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    I'd be more concerned with the draft of air across the desk - could cause problems if you put any sheets of paper on there at all...
  5. joedredd
    joedredd What's a Dremel?
    16 Sep 2008
    Yeah but it will keep your feet warm in the winter :)
  6. ThaNerd
    ThaNerd What's a Dremel?
    6 Aug 2008
    Wood has much more problems with humidity than with temperature... And as Krikkit said, even if you overclocked a bi-phantom with 4 SLI GPUs, the temperature wouldn't be high enough to affect the wood...
