Case Mod - Complete Rage - elite 130 casemod
Discussion in 'Project Logs' started by MooZ91, 1 Apr 2017.
  1. MooZ91
    MooZ91 What's a Dremel?
    6 Jul 2012
    This project will use a Elite 130 mini itx case, with some ideas on the way.
    Some cuts for the case let me think about some ideas... checking the space for a sided-psu and new look for front.
  2. MooZ91
    6 Jul 2012
    some misc, and setting the support for the psu.
  3. MooZ91
    6 Jul 2012
    A cool project deserves a cool logo
    As result of moving the PSU, the existing hole had to be cover in some way. i take advantage of the space to place a 80mm fan, helping to extract the hot air from the cpu cooler. Of course, not only that but a few details to match the theme.
    found some tube fittings in the garbage... i guess it will has a second life.
  4. MooZ91
    6 Jul 2012
    Updating the front... The best part, most of the pieces are recycled from previous works, only with a jigsaw gives the shape needed.
    plus, other details
  5. MooZ91
    6 Jul 2012
    working on top
  6. MooZ91
    6 Jul 2012
    Paint it white!!... and other colors D:
    The snow V6GT :D
  7. kim
    kim hardware addict
    10 Jan 2016
    impressive result...amazing hand and paint job, I enjoy and follow...:thumb:
  8. MooZ91
    6 Jul 2012
    Thanks for check :D
    Found an old webcam... here starts the transformation to super cannon D:
    A few details, paint, airbrush and misc...
  9. MooZ91
    6 Jul 2012
    More details...
    The mixed color for Sleeving: White, gray and Black.
    Testing the lights, first at bottom, but on top has better results.
    finally, the damaged fan on front... the intake airflow will ensure the good work of the cpu cooler.
  10. kim
    kim hardware addict
    10 Jan 2016
    great fan "damaging" but isn't it noisy when turned on with those cuts in the wings?
  11. MooZ91
    6 Jul 2012
    Thought the same after finish, but the fan spin below 1500 RPM, barely feeling any noise. Any way, it is connected a fan controller to track the speed.
    Few details more, an i/o shield to the mobo, and special thanks to AVEXIR for these awesome memory pack.
    The "brain" of this unit, modeled in polymer clay, then airbrushed.
    Misc...
  12. MooZ91
    6 Jul 2012
    Finally, here is the result!
  13. David
    7 Apr 2009
    Great work - it looks fantastic.
  14. MooZ91
    6 Jul 2012
    Thanks!
    Do not miss the video!
