Windows RAID 0 questions!!!
Discussion in 'Software' started by sik wit it, 13 Jul 2004.
  1. sik wit it
    sik wit it What's a Dremel?
    1 Jul 2004
    when you configure 2 physical harddrives to run in RAID 0 striped, do they show up in the OS as one hd??? in other words, windows explorer would display it as one hd directory? ex. C: or D:
  2. Perpetual Notion
    Perpetual Notion What's a Dremel?
    28 Jan 2004
    Yes, they will show up in windows as a single hard disk (as will any other RAID array).
    Perp
  3. sik wit it
    1 Jul 2004
    thanks :thumb:
  4. Perpetual Notion
    28 Jan 2004
    No prob, bob.
  5. sik wit it
    1 Jul 2004
    another question...would it be possible to copy my entire harddrive (2 partitions) onto the 2 drives that are in raid? so in essence i would just be able to convert my single drive setup into a raid setup?
  6. Pash91
    Pash91 What's a Dremel?
    25 Jun 2004
    Turning a single drive into raid would not work becuase it kills the whole idea of RAID. RAID is used to either improve performance, provide redundancy, or do both. By using 1 drive RAID is not possible since you cannot stripe data across two drives, mirror it on two drives, or both
  7. lechumbl
    lechumbl What's a Dremel?
    29 May 2004
    Hi all,
    You need a minimum of two drives to make a RAID array in RAID 0 and RAID 1
    Three are required to make a RAID 5 array.
    Take care...........
  8. sik wit it
    1 Jul 2004
    AAAARRRRRRGHHH!!!!
    i know this!!!
    I am saying...for example....
    I have my one drive now (we'll call it drive C)
    I set up 2 drives in RAID 0 striped so that "Partition Magic" or a similar program sees it as 1 drive (we'll call this drive D)
    would it be possible for me to copy drive C onto drive D???...thus, converting a single drive system into a raid system????
  9. lechumbl
    29 May 2004
    Hi,
    I was going to answer your question, but you screamed at me.
    Take care.........
    PS..........Yes you can.
    After makig the RAID array, use Ghost or PQDI to make an image, then restore it to the new "drive".
    I do not mind being screamed at, I am married. :D
  10. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    only issue you might have is windows might not boot what with not having the raid driver installed
  11. Pash91
    25 Jun 2004
    I was wondering, since were talking about RAID, is there a way to clone a RAID array? I have Ghost and on Symantec's site, it says 2003 can't clone arrays. Under some circumstances it can, but not necessarily. I don't know about 2004 but maybe other programs? Any ideas?
  12. Boldar
    Boldar Minimodder
    24 Feb 2003
    I do it all the time using ghost 2003 no problems yet mind you I do it partition by partition rather than the complete drive.
  13. Pash91
    25 Jun 2004
    So Ghost sees the arrays as 2 drives? So I can make an image of both partitions, store them for safe keeping and later actually restore it and have my RAID fully working again?
