Modding raidmax ninja
Discussion in 'Modding' started by rswami92, 3 Feb 2007.
  1. rswami92
    rswami92 What's a Dremel?
    2 Feb 2007
    Essex, UK
    anyone know anything about the raidmax ninja case thinking of getting cos its at a decent price and looks well good.
    got anything good or bad to say about it or any other reccommendations i can get in the uk :D
    http://www.raidmax.com/specs/ninja.htm
  2. Gaspowered
    Gaspowered What's a Dremel?
    6 Aug 2006
    ive had raidmax cases before, there generally very solid cases with standard internal designs (the tried and tested stuff). If my one was anything to go by, watch the front panel, as they tend to be a bit flimsy.
    I like the alienware styling btw :)
  3. Naberius
    Naberius What's a Dremel?
    20 Nov 2006
    UK
    Front Panel is flimsy, the motherboard tray warped and the side panels are a pain to get on and off, based on the one i had, AVOID!
  4. Gaspowered
    6 Aug 2006
    lol, i guess you get what you pay for, and i got exactly £19.99's worth.
  5. mattthegamer463
    26 Nov 2004
    Canada
    My friend has one of those. It nice and shiny, but lacks quality. I wouldn't personally buy it, but its worth that much.
  6. rswami92
    2 Feb 2007
    Essex, UK
    anyone recommend a decent case then has to be in the uk though having so much trouble always see a good one but it turns out to be crap
