Windows RAM Checking Software
Discussion in 'Software' started by Carlk, 14 Oct 2004.
  1. Carlk
    Carlk What's a Dremel?
    10 May 2004
    hey, wonder if anyone can help me... i need some software to check if my RAM is fulty, is there such thing? ive tryed Googleing it but it comes up with useless info.
    cheers for any help
    Carl
  2. Mister_Tad
    27 Dec 2002
  3. Carlk
    10 May 2004
  4. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    memtest86 is very very out of date, hell it won't even run on my desktop.
    try.
    http://www.memtest.org/
    (its just an updated memtest86!)
  5. Pantharen
    Pantharen What's a Dremel?
    17 Aug 2004
    Memtest nor any software will check the integrety of your ram, to check if it is faulty, you'll have to run something that tests hardware. There use to be a card you would purchase called a POST CARD. You just plug it into a pci slot and it spits out codes.
    However if your ram was faulty, your computer wouldn't boot properly, you would be getting a **** load of hardware issues, and you sure as hell wouldn't be online.
  6. Dinh
    Dinh What's a Dremel?
    27 Jun 2004
    or better yet, try the Micro$oft one
  7. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    Actually, I bought a POST card just recently due to a problem very similar. I got it from Startech.com. Works great.
  8. Tech-Daddy
    Tech-Daddy What's a Dremel?
    8 Oct 2003
    Quite interesting you would state that. I just used memtest to note the "which", "where", and "how bad" my memory was failing.
    I have a bad DIMM from OCZ, and memtest not only helped me to pin down "which" DIMM was flaky, it told me where (the memory address range) as well as "how bad" (was it immediately reproducing errors or were they heat related/board compatability related/etc.
    I'd say memtest is just about as good as you can get, short of buying a hardware memory checker that you allude to. Those dudes are bodaciously expensive. memtest is free.
    Gimme free anyday!
  9. hardflipman
    hardflipman What's a Dremel?
    27 Jul 2004
    yup, i agree, i just used memtest to check ram and it told me which dimm was faulty. and now the machine works(without the duff ram). brilliant
  10. cpemma
    cpemma Ecky thump
    27 Nov 2001
    There's also DocMemory a freeware teaser for their hardware solutions. It won't tell you which chip in a stick has failed, but you're not going to solder a new one in, are you. ;)
  11. Mister_Tad
    27 Dec 2002
    i think he was trying to say that if ram is properly pooched, the pc wouldnt boot at all, and you wouldnt be able to run memtest
    but memtest is great for identifying if a problem with a system is ram related
