Other Rant on motherboard headers
Discussion in 'Hardware' started by MightyBenihana, 12 Dec 2019.
  1. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
    How f**king stupid is it to have a single 2.0 usb internal header on a £200+ high end gaming motherboard in this day and age, even if it is mitx. So many things exist which plug into these. 1. F**king 1.
    Asus, I am looking at you. Jesus titty f**king Christ.
  2. sandys
    sandys Multimodder
    26 Mar 2006
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    I sense the OP is annoyed, i maybe be wrong though. ;)
    Aren't internal headers only (mainly?) used for connecting up the cases front ports and don't most cases come with USB 3.0 ports these days? In other words i can't think of many things that plug into internal headers but if you're saying there are there must be.
  4. Anfield
    Anfield Multimodder
    15 Jan 2010
    Aquaero, some PSUs with software monitoring, card readers, some RGB controllers.
  5. Gareth Halfacree
    4 Dec 2007
    The daft RGB lighting on the stock heatsink with my Ryzen, too, if you don't have a dedicated RGB header on your motherboard.
  6. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Corsair AiO coolers need a USB2 header too.
    Luckily, My mobo has 2 & a USB3 as well.
  7. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Some fan controllers (e.g. the Grid+) need a USB 2.0 header, iirc.
  8. Corky42
    30 Oct 2012
    You all had to do it didn't you, now i look like an arse, I asked for that didn't I. :D ;)
  9. Anfield
    Anfield Multimodder
    15 Jan 2010
    Don't worry, once King Blowhard has his coronation tomorrow no one will remember the before time:p
  10. Vault-Tec
    30 Aug 2015
    I use so many I've got two 7 port hubs in my main pc.
    The case uses it (two!) And then every AC device like farbwerk for RGB, Aqua aero for pumps, PA3 for more fans and so on.
    I'd be screwed without it. In fact, no boards I looked at for Ryzen even had enough. Apart from TR boards.
  11. MightyBenihana
    8 Sep 2011
    I have calmed down a little now. It is annoying spend upwards of £200 on a mobo then have to spend another 15 on a splitter for usb2 headers, more for fan header splitters etc. I am annoyed also because the SF750 cpu and 24 pin cables are too short for the Fractal define nano s and those 2 cables alone to purchase separately are ~£50.
    Every time I have done a build in the last few years I always thing "never again". It's not fun anymore. Next time I may just buy pre-built. Taking the abuse is far easier then the stress this most recent one is causing and the cash I am blowing on parts I shouldn't have to be spending extra on.
  12. mrbungle
    20 Sep 2004
    I have a rather low end but perfectly serviceable Gigabyte B450 Motherboard.
    Has one, yes one case fan header!
