A/V Razer AC-1
Discussion in 'Hardware' started by cannon, 9 Aug 2007.
  1. cannon
    cannon What's a Dremel?
    15 Jan 2004
    Hi all,
    Been a while since ive been around.
    Ive bought a new case, its going to be pretty standard for a while.
    i have the Antec P182 and im wanting to use the front audio connectors (cause I can).
    The antec p182 has Ac97 and HD audio connectors preset - can I use either or will I have to make/convert what is currently there.
    Linky to Razers pin out but it doesnt quite make sense to me
    Cheers
    PAul
  2. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    Found this on the Razer forums.
  3. cannon
    15 Jan 2004
    Thanks,
    same thing as i linked above sorry.
    Terminology just doesnt make sense.
    Does it appear to be standard to ac97 or the hd audio pinouts?
    Paul
  4. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    That would be ac-97 - it's got speaker send and returns, which HD audio lacks.
  5. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    /\ My mobo manual agrees
  6. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    Hi Paul,
    No it's the same image but it has the pin description, I thought that would help indicate where they need to go.
    Good luck
