Notebooks Reasons *not* to buy an XPS 13?
Discussion in 'Hardware' started by Gareth Halfacree, 10 Oct 2017.
  1. sandys
    sandys Multimodder
    26 Mar 2006
    Great thing with dell is they put the whole laptop strip down on their website under the service section.
  2. theshadow2001
    3 May 2012
    Holy bourne again shell Gareth; It works!
  3. Gareth Halfacree
    4 Dec 2007
    Huzzah! Did you see the later message about it not working at startup 'cos the touchpad shows up as two devices?
    Also, did you see my tool for toggling between Game Mode and Work Mode? That's here - just add a menu entry and you can quickly switch the touchpad off while typing (for work) and on while typing (for games).
  4. theshadow2001
    3 May 2012
    Indeed I did see both, there would be no need for a games mode for me. If I did game I'd probably just use the windows half. (Maybe another thread but I could do with some games for this thing so what are you playing on it)
    I was wondering if there was away to blacklist the PS2 device
  5. Gareth Halfacree
    4 Dec 2007
    ...that's good thinking, that - although I'd be worried it'd end up blacklisting the whole damn touchpad by mistake. Still, once I'm somewhere with a USB mouse I can use should it all go wrong it's definitely worth a go!
  6. theshadow2001
    3 May 2012
    I had a wee look around to see if there was a module I could black list but nothing jumped out. I've a feeling they might be both wrapped up in the same driver
  7. Gareth Halfacree
    4 Dec 2007
    Yeah, I haven't been able to figure it out either.
    In other news, this particular figure from PowerTop should almost certainly be taken with a pinch of salt...
    Looks like, for some reason, it thought the backlight was taking 100mW instead of about 5W. Would be nice, that!
  8. theshadow2001
    3 May 2012
    add:
    Code:
    blacklist psmouse
    to:
    Code:
    /etc/modprobe.d/blacklist.conf
    then run:
    Code:
    sudo update-initramfs -u
    The PS/2 mouse won't appear in the xinput list after that and the syndaemon stuff works fine straight from boot.
  9. Gareth Halfacree
    4 Dec 2007
    Niiiiice!
  10. Gareth Halfacree
    4 Dec 2007
    Well, it's official: I can go a solid three days between charges on this thing, with usage concentrated around lunchtimes (Netflix) and evenings (Netflix, posting on 'ere, and IRCing, mostly.)
    Happy with that!
    MLyons likes this.
  11. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Damn, that's impressive.
  12. Gareth Halfacree
    4 Dec 2007
    How's this for a real first world problem: I get a low battery warning and red light on the front of this thing when I've still got an hour and a half left...
  13. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    That's nearly a full charge on some laptops...
  14. yuusou
    yuusou Multimodder
    5 Nov 2006
    That's 50% of my charge.
    Given my hardware and how old my laptop is though, I'd say mines' still doing pretty darn well.
  15. Guest-23315
    Guest-23315 Guest
    On my bog standard Windows 10 13 , the orange gives me ~45/50mins of youtube which is still beyond impressive.
  16. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    I've put in an order for the new Inspiron 13 7000 - 8th Gen i7, 16GB, 512GB PCIe SSD with a thin bezel like the XPS. After cashback and a little extra discount it'll come in under £1000. I really wanted the XPS 13 but I can't justify the extra cash for it.
  17. Gareth Halfacree
    4 Dec 2007
    Bumping this out of the depths, 'cos I've finally got around to undervolting my XPS13. I'd put it off, 'cos I'd always assumed it was going to be a pain in the harris - but it turns out there's a dandy little Python script, undervolt.py, which does all the hard work for you. Now running on -75mV across all undervoltable things. It's still hitting thermal throttle under load, so at some point I may brave a re-TIM with something suitably expensive.
  18. Pete J
    Pete J Employed scum
    28 Sep 2009
    I am effing loving my XPS13. The screen is a work of art - I 'calibrated' it, only to find that the factory calibration was spot on. I also caved and bought a Razer Core X with 1080Ti. Not only does it charge it, it actually works with the triple monitor surround gaming setup I have. Yes, you really can unplug and plug in at will. Utterly incredible. Crysis runs smoothly on it, which means that other games should do fine - looking forward to booting up Star Citizen again.
    Having seen how awesome the 4k screen is on the XPS13, I now am aiming to own a 30" 8k monitor at some point. Be a few generations of GPUs before gaming at 8K is feasible though (and you'll need ideally need at least ~32GB VRAM), plus Thunderbolt version whatever with a much larger bandwidth.
  19. MLyons
    3 Mar 2017
    Have you noticed a difference in temps or battery life?
  20. Gareth Halfacree
    4 Dec 2007
    Performance is a little better, as it takes slightly longer to reach the the thermal throttle point, but it hasn't made a huge difference to battery life.
