Graphics Recomend a Graphic Card
Discussion in 'Hardware' started by blacksta, 14 Aug 2012.
  1. blacksta
    blacksta What's a Dremel?
    1 Nov 2011
    Guys
    Please recommend a graphic card my current motherboard is an Asus p8z77-vlx. I have a vga lcd monitor that i would like to connect to my current setup.
    Bugdet = upto £100
    uses = dont play games but watch alot of movies but might take up the idea of playing games if card cant support it
    Thanks
  2. teppic
    teppic What's a Dremel?
    18 Jul 2011
    If you think you're unlikely to play any games, then a low end AMD card, like a 6450. It'll play older games fairly well, and newer ones on low settings.
    Don't spend £100 unless you're almost certain to play games, as you'll be wasting your money. Otherwise a 7770 is very a good choice for your budget.
