Networks Recommend a MESH set?
Discussion in 'Hardware' started by MiNiMaL_FuSS, 29 Nov 2020.
  1. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    Hi guys,
    Just moved my office into the loft conversion and the WiFi is pretty dire.
    It's an old Victorian property, so not sure the wiring would cut it for home plugs.
    Considering going for a mesh setup to solve the issues.
    It would need to cover 3 floors, ideally replacing the router rather than extending it, and I'd want to make the most of my 100mbs cable speeds on the top floor over the 5ghz band.
    I was considering the following, but would appreciate suggestions.
    https://www.amazon.co.uk/Tenda-Coverage-Parental-Controls-Replacement/dp/B07YZCZSPW
    Thanks!
  2. VictorianBloke
    VictorianBloke Man in a box
    31 Oct 2007
    Have a look at the various TPLink Deco models.
    Main benefit is that you can mix and match different models, so can upgrade single nodes and bump the others further out rather than having to replace the whole system.
    I've been well impressed with 3 Deco M4s covering a 2 floor Victorian terrace for £99. No dead zones anywhere and easily maxes out my 80mbs bband. I probably only really needed 2, but the garden now has WiFi, which was beautiful for home working this summer. :grin:
  3. MiNiMaL_FuSS
    24 Dec 2003
    Thanks for the recommendation.
    I'm planning to get 3 units, one for each floor, so good to know that sounds like plenty.
    After doing some more digging, the TP-LINK Deco M4 seems to outperform the Tenda Novas, so I think that's the way I'll go.
  4. nimbu
    nimbu Multimodder
    28 Nov 2002
    Two of my friends got some of the eero (non pro) that they are very happy with.
    One lives in a modern ish (50s) semi while the other is in a new build.
  5. jsbombjack
    jsbombjack Minimodder
    14 Mar 2015
    Second the Deco recommend. I use the Deco M4, and have found it work work really well considering the price. Definitely better to make sure that 2 of the 3 units are connected to your network via ethernet (because they are dual rather than tri-band), but other than that they are excellent.
    Also, if you have a combination of wired and wireless devices, then make sure they are in AP mode, otherwise all sorts of fun happens ;-)
  6. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    If you have a second router on the network, they should be in AP mode irrespective of whether your devices are wired, wireless, or a mixture of both :)
    I would also go the TP Link Deco route, cracking bits of kit!
