Other Recommend a shower head
Discussion in 'General' started by silk186, 8 Jul 2020.
  1. silk186
    silk186 Derp
    1 Dec 2014
    Not even remotely a tech question but I've had good luck here. I'm renting a ground floor flat with a combi boiler. It had an Ionic Shower Head full of magic rocks that are supposed to ionise the water and remove chlorine or some BS. Apparently, you are supposed to replace the rocks every 6 months. Anyways, I prefer to save my money to buy radiation blocking stickers for my cellphone. I read Mira is good, so I ordered a Mira Response and I'm disappointed as it doesn't perform as well as the magic rock head that has sprung a leak. I don't care about 256 different settings with RGB. As long as it has one stong setting that isn't bunghole I will be good. Mira also suggests I need to spend as much on a new host to increase pressure by up to 25%, is that Mira BS? Anyways, the Mira is going back. Does anyone have recommendations for something good under £30?
    [​IMG][​IMG]
  2. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    If you like the Ionic Shower Head, can't you just keep using without all the magic rocks? Might even get a flow boost. Or you can try it with other materials, replace the energy balls with coffee grounds.
  3. silk186
    silk186 Derp
    1 Dec 2014
    I don't know how old it is, it's unhygienic and it has sprung a leak - the main reason.
  4. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Got to admit you got me there. being bit-tech you should really mod the old one to work or do a scratch build... I'll even make a project log exception :dremel:
    Dr. Coin and adidan like this.
  5. Dr. Coin
    13 Sep 2013
    Oops I missed that detail in the first post.
    FYI a new magic Ionic Shower Head is only £12, less than half your budget and you can get a clone unit with RBG for the same price!
    My partner replaced one of our shower heads a couple years back with a Waterpik brand unit (I think model ZZR-769ME or its predecessor) and it seems reasonable. I haven't noticed any issues despite the over use of plastic. I don't see the model on Amazon.co.uk and what Waterpik units I did see are just above your price.
  6. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
    Mod it with a hammer, then you can put the rocks around a pot plant.
  7. wyx087
    15 Aug 2007
    The free water saving stuff we got from Affinity water are very good, better than an expensive branded one we bought from B&Q.
    It saves water, yet I feel it sprays enough showering water and spread to be comfortable. I also use their water saving connector on the en-suite overhead shower, which reduces water consumption (evident from combi boiler working not as hard) but there's still more than enough water hitting me.
    See here for how to get free water saving stuff.
    https://www.moneysavingexpert.com/utilities/cut-water-bills/#gadgets
  8. silk186
    silk186 Derp
    1 Dec 2014
    "We don’t offer free products in your area however you can still make great savings through our Savings Engine™." - Discrimination! Rabble Rabble Rabble!!!
  9. silk186
    silk186 Derp
    1 Dec 2014
    3D printed shower head based off an AIO backplate design? Seems like a future Bit-Tech article.
  10. silk186
    silk186 Derp
    1 Dec 2014
    I'm very tempted to make a golden shower part of my morning rituals
    Dr. Coin likes this.
  11. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    I got that exact magic rocks head for about £3 from your favourite online Chinese retail outlet, it's not terrible but there's certainly better out there.
    Make sure you check your shower hose and drill out any flow restrictors that are in there to "save water".
    I've been considering this, the reviews are good:
    https://www.amazon.co.uk/High-Pressure-Shower-Head-Showerhead/dp/B07CQH9KSR/ref=sr_1_5?dchild=1&keywords=shower+head&qid=1594306531&sr=8-5&th=1
    I'm assuming I could just fit it to the end of the shower hose rather than needing a proper fitted shower pipe. I've also seen it recommended on a few independant websites.
    Or this:
    https://www.amazon.co.uk/Handheld-S...1&keywords=shower+head&qid=1594306531&sr=8-13
    Is my most likely bet, as I think not being able to hold the first one would annoy me quite quickly!
  12. Cheapskate
    13 May 2007
    I was going to suggest what Minimal said. A shower head shouldn't piss out less water than a bathroom faucet. They are usually in the inlet of the handset and can be removed with long nose pliers.
  13. adidan
    25 Mar 2009
    Dr. Coin and Mr_Mistoffelees like this.
  14. Mr_Mistoffelees
    26 Aug 2014
    Goatee likes this.
  15. Dr. Coin
    13 Sep 2013
    Seems like a bad plot device for a 1980's comedy.
    Mr_Mistoffelees and adidan like this.
  16. Goatee
    Goatee Multimodder
    19 Apr 2015
    Didn’t the CIA try this on Castro?
  17. BeauchN
    BeauchN Modder
    5 Apr 2011
    certainly an exploding cigar, not sure that would have worked in the shower though...
  18. Dr. Coin
    13 Sep 2013
    In a shower you want the exploding oversized sea shell
  19. MiNiMaL_FuSS
    24 Dec 2003
    The bomb proof one just arrived, will give feedback tomorrow....that sounds so creepy...
  20. Mr_Mistoffelees
    26 Aug 2014
