Other Recommend a wall stud finder
Discussion in 'General' started by meandmymouth, 13 Aug 2019.
  1. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    Can anyone recommend a stud finder? I want to make sure I get something reliable so I don't wreck my walls.
  2. legoman
    legoman breaker of things
    28 Feb 2010
    Bosch Truvo, never failed me yet
  3. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Yeah, that's what I have and it's been excellent.
    legoman likes this.
  4. legoman
    28 Feb 2010
    It has little marker line you can make a cross with too, or just square off a no go area
  5. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Piece of string with a neodymium magnet on the end. Works like a charm and costs nothing.
  6. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Cost nothing except for the string and magnet and works if you have steel studs. The true freebie is a knuckle, I'd had mixed success with it though so I cannot recommend it.
  7. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    I use a magnet as well with wooden studs finds the drywall screws easily
  8. Krikkit
    21 Jan 2003
  9. sandys
    sandys Multimodder
    26 Mar 2006
    I have the truvo and it has worked well, it is even good at finding out if your puppy has eaten brass tacks and needs a visit to the vet :D which she did :duh:
    Arboreal likes this.
  10. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    I looked at both the Tacklife and Bosch ones but was a little put off by some of the reviews. Part of me wonders if that just user error, though.
  11. Krikkit
    21 Jan 2003
    I suspect so - they tend to need a little finesse and patience to use, something Joe Public tends not to have...
