Other Recommended a dual monitor stand
Discussion in 'Hardware' started by CrapBag, 23 Oct 2020.
  1. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I recently purchased a couple of 24" monitors from facebook to replace my sons 24" tv and 17" dell dual screen setup he was running.
    He wants some desk space back so I recommended he gets a dual screen stand.
    I want one that clamps to the desk really and I have looked at the bottom end of the range and I'm a bit wary of some of the negative comments like build quality etc.
    So I need some advice as to what to buy but not in the high end bracket (pun intended lol).
    Cheap ones are around £18 and I've seen a couple around the £25 mark, would the extra £7 improve the stand enough or do I really need to be looking a little dearer.
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    For 24" screens I wouldn't worry so much. I'd only be concerned if it was 27" or so as they get heavy! Are you going for fixed horizontal arms or the movable spring assisted ones? If its the former, even the cheaper ones should be fine.
  3. VictorianBloke
    VictorianBloke Man in a box
    31 Oct 2007
    I've got an Arctic Z2 that's holding a 27" and 24" solid as a rock, no issues with build quality at all.
    The basic (without usb hub) is £35 from scan so I wouldn't spend any more than that.
  4. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    THIS
    Not the strongest for heavy monitors but if the 24" monitors dont weigh a tonne they are fine.
  5. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I don't really want to go over £30.
    As for adjustable I really don't know, he's autistic so them being perfectly in line is important so probably.
