Modding Recommended cnc places
Discussion in 'Modding' started by David13, 12 Jun 2012.
  1. David13
    David13 What's a Dremel?
    7 May 2007
    Hey
    I would like to have something made, as it's to complex for my skill level and after trying the local engineering/ metalwork workshops who said that they recomend going to someone who has cnc machinery.
    It's a mid plate for a Lian Li v2110b.
    Anyone got any recommendations?
  2. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Where are you located and what material did you want it cut from?
  3. David13
    7 May 2007
    York, UK. 2mm Aluminium plate.
  4. David13
    7 May 2007
    Anyone?
  5. bluc
    4 Apr 2012
    Have read on these forums a lot of schools and sign writers have cnc machines may be worth doing a search through your telephone directory or just Google "cnc cutting services in York" to get started your best best would be finding a stainless/aluminium workshop with a water jet cnc machine should not be that expensive. Here you go http://www.freeindex.co.uk/categories/industry/industrial_services/water_jet_cutting/ keep sending emails with the drawing till you get a reply that's what I did am in Australia and it took me a few weeks to find someone to do my stuff for reasonable price sorry can't be more help cheers
  6. Nexxo
    23 Oct 2001
    I think that is something you could do with a jigsaw.
  7. whatsthatnoise
    whatsthatnoise What's a Dremel?
    21 Mar 2012
    Agreed, a drill and jigsaw should do it. There's not even a single angle in there. Exact measurement required, though. :naughty:
  8. Reconnec7ed
    Reconnec7ed What's a Dremel?
    29 Feb 2012
  9. Achron
    Achron Cad Pro Quo
    28 Nov 2009
    You would be much better off getting that laser cut or waterjet than thrown on a CNC milling machine. Yes, all of these are CNC, but CNC is typically a term used for milling and lathing.
