Windows Reg. Code
Discussion in 'Software' started by crazydeep74, 21 Jun 2006.
  1. crazydeep74
    crazydeep74 What's a Dremel?
    25 Jul 2005
    I lost the little booklet that came with my 98se disk. I do however have the code from my 98se upgrade cd, will it work with the full install 98se cd?
  2. thingamajig
    thingamajig What's a Dremel?
    29 Nov 2005
    Probably Not...
    Besides 98 Is Basically At End Of Life. IIRC There Are Some Patches That Microsoft Will Not Even Release For 98 Since It Would Require So Much Rework To The Kernel To Get Everything Correct.
  3. Arthur2Sheds
    Arthur2Sheds Jackson
    19 May 2003
    I Agree With Thingamajig.
    Is 98 your only option? If you can, go with XP. If money's the issue, try Ubuntu.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Is 98SE still installed on your system? There's a code number shown in the System Manager box (My Computer/Properties) IIRC, or utilities like X-Setup will show you it.
    If you have a 98SE Upgrade CD it will install everything onto a blank hard drive if you slot an older version into the CD or floppy drive when asked. The older version doesn't need to be already installed.
