is there any way to put a switch outside my room for a switch indside my room, theres this swich inside my room liek a light switch to turn on and off the heater, its annoying when ppl come in to turn it on and off. is there anythign i can buy that can wirelessly put a switch on the outside that can close or open the curcuit inside my room..
X10 stuff will do that. www.x10.com (They are a good place to buy, just DONT fall for their "End NOW!" sales pitch)
thanks.. zap, i dont know which product has this kind of feature. can u direct me to a link. thanks a bunch
x10 has a solution for that too: http://www.x10.com/automation/x10_ws467.htm Although, you do have to use it with a kit, I think.
would that work with a heater switch, see my house is a old one and still uses a old switch to turn it on and off in the basement, but my folks wired it so that the switch is in my room (best route up), so now its mad annoying, when i'm like sleeping they wake me up to turn it on or off and either that or i have to leave my door unlocked.. which i hate... in other words.. the switch is for some kind of heating system, the switch u showed me is Rated at 500W (incandescent). is this good enough?
I don't know, what is the heater rated for?? I would guess that the heater is a little higher than 500W, but you never know...
You always could use one of these: http://www.x10.com/automation/x10_hd245.htm and activate it remotely with one of these: http://www.x10.com/automation/offer95.htm Just start browsing the x10 website, and you'll find all sorts of stuff you need
