remove U3 system on USB
Discussion in 'Tech Support' started by Samm, 4 Jul 2008.
  1. Samm
    Samm What's a Dremel?
    4 Jul 2008
    Hello everyone, I recently purchased a Sandisk Micro Cruzer 8GB with a U3 system - Fatal mistake.
    At first I saw the U3 system, and decided that formatting the thing would make it a normal USB drive, and .. I'm proved wrong. Acting without researching now leaves me with a piece of dead plastic. It won't do anything. It detects the drive as FAT32 and 0 diskspace, detects the U3 as a CD-ROM, yet it becomes read-only.
    I cannot remove the U3 from it with any installers i've downloaded, and now I don't know what to do.
    Does anyone have any solutions to this? :wallbash::wallbash:
  2. monkeybone
    monkeybone What's a Dremel?
    28 Jan 2005
    Well to remove U3 you need to use the uninstall directly from their site.
    HERE
    Try that first. If not, just go back to the store you bought it and exchange/return it.
    Monkeybone
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    If that doesn't work, try restoring the U3 system to repair the damage you've done, then uninstall it properly.
  4. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I like to use the U3 programs when I go to the somewhere that might not have the programs you need
  5. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    reformat the thing as fat32. i use gparted, but i think windows disk manager should do it.
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    The HP utility has always worked for me and will make a bootable pendrive.
