Graphics Removing the HIS IceQ
Discussion in 'Hardware' started by GunDam, 18 Jul 2005.
  1. GunDam
    GunDam Minimodder
    9 Feb 2002
    Has anyone had any experience in removing the stock IceQ that is mounted on a X800 XT card?
    I've finally plucked up the courage to added the card to my waterloop and I'am thinking of buying some Tweakmonster BMG ram sinks.
    But 1st I need to know whether the IceQ and the ram heatspreader plate is stuck on and if it's easy to remove.
  2. Tim S
    Tim S OG
    8 Nov 2001
    easy to remove, very easy. Unscrew the back and it should pop off with a little bit of gentle encouragement from a screw driver
