News Researchers create camera fabric
Discussion in 'Article Discussion' started by CardJoe, 8 Jul 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. mjm25
    mjm25 What's a Dremel?
    19 Jan 2009
    Will we see Stealth from this? combine a photographic layer and a projection layer in one piece of clothing and you would have enough of an image to camouflage at long distance or in largely cluttered areas.
  3. mrb_no1
    mrb_no1 Pie Eater
    15 Sep 2007
    exactly my initial thought. cool stuff
  4. Necrow
    Necrow Minimodder
    24 Feb 2009
    Ah active camo like in BF2142 - good stuff, no use other than military or burglary but good stuff all the same
  5. sub routine
    sub routine Archie Gemel
    27 Sep 2007
    thats pretty fascinating, wallpaper the house for the ultimate surveillance tool.
  6. SteveU
    SteveU Minimodder
    19 Jun 2009
    You forgot locker rooms of the opposite sex!! lol
  7. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    A crimbo jumper from your gran, could take on very sinister connotations:)
  8. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    What wavelengths might those be?
  9. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    I want a jumper like that! No idea what for but it would make me soooo cool! :eyebrow:
    Seriously... grow up. As impressive as it sounds, it won't be nearly as good once it's on the mass market and it'll be way overpriced and pretty useless due to the first part of this sentence.
  10. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    are you having an argument with yourself there?
  11. perplekks45
    9 May 2004
    I just summarized some of the comments above. But after I just read it again myself... I failed. :wallbash:
  12. Deadpunkdave
    Deadpunkdave ...why you need a 20-sided die
    9 May 2009
    Projection in stealth technologies is always flawed since you are taking the image of a wave at a surface then projecting that image from a point or array of points. This looks unconvincing, particularly as distance between an observer and the object varies due to the differences of far and near field diffraction from a point source. Also, no colour reproduction is perfect so there will differences between the image and projection anyway. You have to refract the actual incident light rays around the object in order for "invisibility shrouds" to work. This has been done in 2d on a small scale, browse newscientist.com or search journals for details. Still a good decade away from macroscopic applications of such technology by most estimations I'm afraid.
  13. Skill3d
    Skill3d Minimodder
    29 Sep 2005
    well you wont be invisible with your stealth suit YET, but it will do for some ranged stuff besides if military thinks the same they'll be developing some mil'stuff which will be higher grade offcourse.... this is pretty neat tho... bring in them stealth suits...
  14. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Here comes the new upskirt rage...
Tags: Add Tags
