Planning Reset button replacement
Discussion in 'Modding' started by RadEd, 22 Jun 2011.
  1. RadEd
    RadEd New Member
    4 Aug 2010
    I tried painting the power/reset buttons on my case, all went well until I tried to fit them into the case, the paint got scratched and they got stuck.:wallbash:
    They are now beyond repair, time for a rethink, I will likely use a vandal proof switch for the power button, but not sure what to do about the reset button, I have been thinking of using a smaller 16mm vandal switch but I'm not too sure.
    I need to do something with the small hole whatever I do.
    Anybody got any Ideas?
  2. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    Poke a pinky in there, or if you're feeling game, use your thumb :naughty:
  3. TeeJay88
    TeeJay88 Whens the Damn Zombie Apocolypse
    9 May 2009
    The 16mm wont work, this is a lian li right, call them up and see if you can get a replacement. Im sorry I cant be of any help.
  4. PabloFunky
    PabloFunky New Member
    19 Sep 2010
    Those holes look too close together to use a larger and a 16mm switch.
    The switches would prob overlap each other, 22mm bezeled switch requires a 19.2mm hole
    Any momentary switches will work, its just physically fitting that will be the issue.
