Electronics Resistors in series
Discussion in 'Modding' started by bigal, 6 Apr 2005.
  1. bigal
    bigal Fetch n Execute
    8 Oct 2004
    Hi again!
    I need to know, if i need 6.8 ohm resistance at 1.5w and i cant get 6.8 ohm resistors, but i can get:
    4.7
    2.2
    at one watt, if i put them in series, i know it will be 6.9, but close enough, bet they are 1 watt, now i wondered 2 things:
    since they are 2 resistors, surely they only dissapate 0.75w each, or one 1 watt and one .5watt in accordance with their resistance OR maby they both need to be 1.5W?
    Also, since this is in a chaser system, and they are only powered 1/10th of the time if it matters if they get a bit warm when on...
  2. MaplinMan
    MaplinMan What's a Dremel?
    8 Feb 2003
    i cant be arsed to do the maths for you but if you need a 1.5watt 6.8ohm resistor just figure out how much current is going through it.
    then you will know that if there is that much current going through the other 2 resistors u plan on using, how much wattage that is going to produce...
  3. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    Since the currents are the same, just divide the value of the resistor by the sum of the resistors. That will give you the percent of the sereies. The wattage and voltage dropped are proportional. in this case the 4.7 handles 68% of the load.
  4. nick01
    nick01 What's a Dremel?
    6 Nov 2004
    P = R * I^2 , I = sqrt(P / R)
    You have: 1.5W = 6.8Ohm * I^2, so I = 0.470A
    For the two replacement resistors:
    P(2.2 Ohm) = 0.485W
    P(4.7 Ohm) = 1.037W
    I give the 4.7 Ohm resistor a few hours to live, perhaps a week if you place it in front of a fan. Can you get 3 X 2.2 Ohm in series? It wouldn't be so hard on the little critters.
  5. bigal
    8 Oct 2004
    its only going to be on 1/10th of the time anyway... its not much overloaded, .037 w over isnt much, i am sure it will be ok..
  6. MaplinMan
    8 Feb 2003
    why have so much current going through a resistor in the first place tho
  7. bigal
    8 Oct 2004
    because 20 LED's in parallel at 4.5v need a resistor to take it down to 2.2v and since thats in series that requires 20 x 20 ma = 400ma.
    if you "do the math" you need a 1.5 watt resistor. hopefully it is all sorted now.. :) i have my 4017 board with the dual 2N2222 's working a treat... will take some pics when it is all finished.. :)
  8. MaplinMan
    8 Feb 2003
    as a nerd i could tell you that maybe a transistor would mean there is less load on the rest of your circuit and should be used in that situation.
    but as a nerd basher, ill just say good luck with your project :D
  9. cpemma
    cpemma Ecky thump
    27 Nov 2001
    How do you imagine another transistor would help in this situation? :sigh: :read:
