Windows Restore My Documents to Default location
Discussion in 'Software' started by Kronos, 30 Mar 2013.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    I have been helping a guy out with his build via email and I gave him instructions how to move the My Folders off the SSD to the 1TB HDD.
    I normally create folders on the destination drive and then move the originals. Which I told him to do except he did not bother with the My Documents folder so in effect the whole of the 1TB drive is now my documents but without a folder called as such.
    It is simple enough to restore to a default location provided there is a folder to restore but I have not got a clue what to do in this situation.
  2. T2I3M
    T2I3M Minimodder
    13 Mar 2010
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    No need to restore the folder... you can just create a new folder, move the data into in and then go through the move procedure to select it.
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    this ^^^^^^
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    What do you mean exactly by the lat part of your post, "then go the move procedure to select it" I want to be absolutely clear when I pass the details on. Do you mean go back to the original My Documents folder and move that to the newly created folder?
