Case Mod - Complete Revenant V04
Discussion in 'Project Logs' started by MooZ91, 2 May 2018.
  1. MooZ91
    MooZ91 What's a Dremel?
    6 Jul 2012
    Hello friends, here I come with another project. This one based on the Coolermaster Masterbox Lite 3.1, hope you like it!
    First at all, reviewing the case... It has a lot of good features, i really like it.
    Now the time for disassembly and cut :D
    With you, the new Masterbox Lite little 3.1 xD
    I'll keep the front too, meanwhile i'm thinking new ideas for the hardware.
  2. birdie
    birdie What's a Dremel?
    5 May 2003
    Any updates?
  3. MooZ91
    6 Jul 2012
    Yeah sorry for the delay.
    After decided to relocate the motherboard, the construction of supports begin. Starting with simple aluminium angles, i decided to do something better, mixing with the main theme.
    Thinking about some led lights inside the suports...
    What is left of the front, also will be used for cover the vcard, also in the same orientation of the MoBo.
  4. MooZ91
    6 Jul 2012
    Placing the vcard, and re-using the original front of the case.
    Plus! more details :D
  5. MooZ91
    6 Jul 2012
    Here comes a big update, a lot of cutting, fixing, painting and details! The best part is, most of the details, comes from the same case parts xD
    Redesigning the gun base, to fit in the new mini reservoir on top!
    More recycling!
  6. MooZ91
    6 Jul 2012
    Time to assembly after painting some shadows and details... For watercooling the pump was mounted on the fan-rad.
    IMG_3119.jpg IMG_3121.jpg IMG_3129.jpg IMG_3135.jpg IMG_3126.jpg IMG_3125.jpg IMG_3130.jpg IMG_3134.jpg IMG_3137.jpg
  7. MooZ91
    6 Jul 2012
    Here is the outcome... a different form factor with a lot of RGB :D Hope u like it!
    IMG_3211.jpg IMG_3216.jpg IMG_3220.jpg IMG_3223.jpg IMG_3240.jpg IMG_3249.jpg IMG_3267.jpg IMG_3284.jpg IMG_3286.jpg IMG_3290.jpg IMG_3211.jpg IMG_3216.jpg IMG_3220.jpg IMG_3223.jpg IMG_3240.jpg IMG_3249.jpg IMG_3267.jpg IMG_3284.jpg IMG_3286.jpg IMG_3290.jpg
  8. MooZ91
    6 Jul 2012
  9. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    WOW :jawdrop: you win man! :rock::rock::rock::thumb:
    MooZ91 likes this.
  10. Cheapskate
    13 May 2007
    Acquires case, proceeds to break it down almost to it's component atoms, calls it a mod. :lol: This borders on scratch build, and you know it. :D
    I love it. It's absolutely nuts!
  11. MooZ91
    6 Jul 2012
    Not a casemod, not a scratch build, The no man's land haha
