Blogs Revisiting the Akasa Enigma
Discussion in 'Article Discussion' started by Tim S, 27 Mar 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    Poor Akasa, the case just isn't working as they'd hoped is it? I hope they can fix the problems soon, because on the surface it looks like quite a sweet little product.
  3. Aragon Speed
    Aragon Speed Busily modding X3: Terran Conflict
    12 Jan 2009
    It seems the 'enigma' part of the name is referring to 'how do you manage to get it to work'. ^^
  4. Jenny_Y8S
    Jenny_Y8S Guest
  5. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    Ok, if you had a SATA cable that was right angled at both ends would you have been able to get the hard drive in?
    Still, the case is a bit of a failure - shame really.
  6. Singularity
    Singularity ******* Operator from Hell
    2 Mar 2008
    Now, here's a stupid idea... why not put the hdd and optical drive UNDER the motherboard tray? Wonder why no case-makes thought of that...
  7. Dreaming
    Dreaming What's a Dremel?
    31 Jan 2007
    stupid question but did you try using the sata cable the other way round i.e. the 90* side into the motherboard and the straight side into the hdd?
    I dunno, they must have got it to work in their labs and whilst there are obviously design flaws i really struggle to understand how akasa with a fair repertoire of case building expertise can get it so wrong as to not be able to fit a hard disk in!
  8. Tim S
    Tim S OG
    8 Nov 2001
    Yep, the PSU wires get in the way and there's a risk that you'd break the SATA port off the drive given the amount of pressure you'd have to apply to secure the drive in place.
